Salta al contenuto principale
Strumento professionale utilizzato molto probabilmente per la manutenzione di telefoni Nokia. Il dispositivo è progettato come dongle con lettore di schede interno.
I didn't know the e-composite reference
can you help me? This electronic component, as in the picture, was removed from the xtw100 device, and I did not find it. I want to know its full name, quartz, and its reference, in order to replace it or change it with an alternative. Please help me and thanks.
Immagine
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi,
Here's a link that shows the schematic for the programmer.
The crystal oscillator schematic component ref ID is Y2 and it has a frequency of 8MHz as can also be seen on the component in the image you posted. There is no other information as to its other specifications i.e. load capacitance, drive level, ESR etc so it will be difficult to know what the exact replacement would be. (examples only).
It may save a lot of time and hassles if you just purchased a new programmer. (supplier example only) as they are not that expensive.
Punteggio 2
Aggiungi la tua risposta
Ahmed Paradoox sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 20
Tutti i Tempi: 513
