Salta al contenuto principale
Smartphone al top di gamma Huawei lanciato nell'aprile 2019. Caratterizzato da uno schermo OLED da 6,47" FHD+, sensore impronte digitali integrato nel display, fotocamera principale da 40 MP con teleobiettivo da 8 MP e da una nuova tecnologia per l'altoparlante voce. Modelli VOG-L29 and VOG-L09.
What resistors are these? (zxw)
I accidentally broke three resistors on the main motherboard of the device. And I want to solder the resistors independently.
I would be happy if someone who has the software zxw can find me the resistance level and the size of these resistors.
(By the way, so that more people can use this in the future, I will mention that two of them are on the sim way)
I marked the resistors here.
Thanks!
huawei p30 pro
Questa è una buona domanda?
Punteggio 3
6 Commenti
@haim1, What is the board number on your phone? I’ll see if I can dig up a schematic and boardview.
da
@geirandersen L 29 if you talk about that
da
Mostra 1 altro commento
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Had a look at XZZ, since I tend to not use ZXW where schematics are concerned. Resistors in question are as follows:
R3003 (green) 47 ohms
R3001 (yellow) 100 ohms
R3006 (orange) 1K ohms
Hope that helps!
Adding 01/31/2023 - for Андрей Лукьянов
According to the files I have
C2901 (red) schematic says 100n? Which i would interpret as nanofarads? That's sort of an atypical way to write that, I would have just said .1µF but that's beside the point.
R2902 (blue) 2K ohms
C2906 (purple) 33pF
Punteggio 5
12 Commenti:
Thanks you.
Just to be sure.... can you write me the size of the resistors?
And one more question... I search on googleans some websites "R3003" for example and i dont find this power of resist (47ohm). Why?
da
@haim1 R3003 is the components designation on this exact board, it’s value is 47 ohms. As for size (package), it’s most likely 0402
da
Thanks!!!!!!
da
@haim1 @geirandersen is correct about the designations. That's just how Huawei refers to the resistor in that location on that specific board. So they don't have to say the resistor fourth in from the left, or something like that.
As for size, the schematic doesn't specify. 0402 is quite large for a resistor, but they do look bigger than resistors on most iPhone boards, which is what I am most accustomed to (those are almost always 1005). So I would wager you're right. Either than or 0201.
da
@flannelist I almost wrote 1005 without even considering anything else, but I took a last look at the picture in the question and I realised the pads looked fairly huge. Now, they could very well be 0201, my eyes ain’t that good looking at a picture on then screen :P
da
Mostra altri 7 commenti
i have also similar question does anyone knows values of mentioned components please ?
Punteggio 0
Aggiungi la tua risposta
Haim Falah sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 43
Tutti i Tempi: 1,369
