Salta al contenuto principale
Repair and disassembly information for the Dyson AM10 humidifier.
1 Domande Visualizza tutte
What does a Piezo do?
My AM10 has stopped misting, doesn't draw any water from the tank.
I am trying to troubleshoot it.
First stop is something called a PIezo, which is accessed from a panel on the bottom of the base unit.
my looks to be in poor condition but I don't know if it is the source of the problem. in fact I don't even know what it does.
it appears to have a watertight seal. so it must be sitting at the bottom of the water tray.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
4 Risposte
Risposta Più Utile
@pjstock, A piezo is basically a “speaker” or more commonly known as a buzzer.
I say “speaker” because because it’s not playing sounds as a speaker, it’s only really capable of producing tones in given ranges.
You can Google “piezo buzzer” if you want to read and understand more about it :)
Punteggio 2
Google it. Loads of different types.
Punteggio 1
Hi. I have the same issue with my am10. Have you found a solution?
Thanks! I’d appreciate it!
Punteggio 0
1 Commento:
change it will help. I also have the same problem and find it in amazon https://www.amazon.com/dp/B0BWN3BZR8
da
I think in this device working the piezo element not like speaker but like object size detector. Same like in dyson vacuum cleaner. Small pieces hitting the piezo, thats generate a very small current, from this currend is calculated how many and how big pieces was catched.
Punteggio 0
Aggiungi la tua risposta
peter stock sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 29
Tutti i Tempi: 958
