Salta al contenuto principale
External storage options by Seagate, usually connected by USB, available in many storage sizes and form factors.
46 Domande Visualizza tutte
Seagate Business NAS acting abnormally
I have just acquired a Seagate Business NAS 2 bay. It didn't have the original power supply, so I bought one from Amazon. It seems to work normally, but I'm unable to turn the unit off via regular methods. I connected it to my network and downloaded the requisite software. The software found it, and I can access the maintenance page via IP address in my browser. It even found the hard drives I put in there.
The problem is I'm unable to factory reset it so I can make use of all functionality. I followed the instructions in the manual and it refuses to reset. Is there anything else I can do to make this work?
Questa è una buona domanda?
Punteggio 1
9 Commenti:
@enron_hubbard how did you try to reset this? Which one of these steps does not work for your device https://www.seagate.com/manuals/network-...
Flashkey? Interesting. Probably has the NAS-OS on it to reboot and reset. https://www.seagate.com/support/kb/busin...
See what you can get from here https://www.seagate.com/support/external...
da
When it was on, I held down the reset button in back. First for 5 seconds, then 10,then 15. The manual stated the light would flash, but none of that happened.
da
@enron_hubbard Used the paper clip yet :-) ?
da
@oldturkey03 Is there another reset hole that only a paper clip can fit in? I was able to poke the button with a pen.
da
@oldturkey03 This thing refuses to turn off or reboot. Short press, long press, this thing just stays on. Is there a USB key I can make to automatically load NAS OS?
da
Mostra altri 4 commenti
Aggiungi un commento
1 Risposta
Have you tried contacting Seagate support? I would do that.
Punteggio 0
2 Commenti:
The unit has been out of warranty for years, typically companies just direct you toward buying a new unit.
I searched for forums but apparently Seagate has shut theirs down.
da
@enron_hubbard - That maybe true, but if you don’t ask there’s little we can help here.
da
Aggiungi la tua risposta
Jay Davidovich sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 82
