Salta al contenuto principale
L'aggiornamento di marzo 2015 del MacBook Air 13" di Apple ha processori di quinta generazione Intel Core i5 e i7, risultando in una migliore performance e maggiore vita della batteria.
install new battery from ifixit, but battery only last for 2.5 hour
Purchased a battery from fixit to replace the OEM battery in MacBook Air 2015. After installation, and calibration, the battery only last for 2.5 to 3 hours before completely drained. I calibrated the battery as stated on the website multiple time and it does not seem to help the issue.
Should I be getting longer battery life than that? I remember the OEM battery last couple 6 to 8 hours for normal use
I use Coconut Battery to look at the battery. It looks like the battery was made almost 2 years ago, and it is only charging to 92.5% of the designed capacity.
Immagine
Any suggestions will be helpful.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Make sure you don’t have something running hard or wild, open Activity Monitor app to see if something is chewing your power
If you don’t see anything, I would contact iFixit to get a replacement, clearly 2.5/3.0 hours is not normal.
Punteggio 0
Get it replaced, sounds like you got old stock. This is why I don’t buy parts from ifixit, only tools.
Punteggio 0
2 Commenti:
Where would you recommend getting parts from?
da Condividi
@strongbow - I’ve used their batteries for quite a few years and many others have as well. COVID has messed up a lot of supply chains, iFixit has of late been bit a few times, in any case they have always stood by their warranty.
@mic85 - Did you contact iFixit? I’m sure they will take care of you as long as it’s under a year (even being over a few weeks I’ve seen them take care of their customers)
In any case make sure you get a good warranty and from an outfit that’s been around at least a good five years.
da Condividi
Aggiungi la tua risposta
Jason sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 28
Tutti i Tempi: 516
