Salta al contenuto principale
“Mouse” bar (left touch) not working properly
Hello everyone,
The left side of the mouse bar is working badly lately. What part I need to look for to replace ?
It seems being the mechanical part of the mouse bar because when I press it it stay down.
Regards
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
The trackpad is part of the uppercase assembly. Here’s the guide MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Upper Case Replacement
Finding the part will be tricky! Most are from used systems these days so be careful! Make sure you can return it if it’s not in good shape.
Punteggio 1
4 Commenti:
Many many thanks for your reply.
Does it has a spring or similar under the trackpad?
da
@matteo tettamanti - There’s more involved than a spring which is the failure. The trackpad or case can be distorted, the micro switch and just dirt jamming it up. Sadly, Apple didn’t make this assembly repairable.
da
perfect ! i'll deal with it due to the fat still working even if not perfectly "just" after 16years LOL MANY THANKS
da
@matteo tettamanti - If you’re set, don’t forget to accept the answer - Thanks!
da
Aggiungi la tua risposta
matteo tettamanti sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 151
