Salta al contenuto principale
Modello A1419 / EMC 3070 / Metà 2017 / processori Core i5 3.4, 3.5 o 3.8 GHz o Core i7 Kaby Lake 4.2 GHz (id ImAC18,3) / Retina 5k display. Fai riferimento alle guide del modello più vecchio dell'iMac 27" Retina 5K display (fine 2014 & 2015), dato che il sistema è molto simile.
293 Domande Visualizza tutte
Is this anti-static tape?
I’m replacing the display on my iMac 27” (mid 2017). While swapping out the new display, I notice the replacement doesn’t have the same black “tape” on the back of the monitor. I think it’s there so the display back doesn’t touch any of the power components.
Anyone know if this is anti-static "tape"? If so, would anyone know where I can purchase it.
Thanks!
Questa è una buona domanda?
Punteggio 0
2 Commenti
@mayer Maybe you know?
da
@beanman56 Dan got it.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
The function is strictly Insulating to prevent an electrical pathway. Anti-static materials are conductive, and in some cases resistive as they don’t always need to be highly conductive.
As an example an anti-static mat has a high resistive value to prevent lower voltage devices from shorting out, yet allow a high voltage static charge to dissipate.
Punteggio 3
4 Commenti:
Thank you for this. I need to look for is insulating tape?
da
@danj Thank you!!
da
@nosaut - No problem! If you’re set don’t forget to score & accept the answer - Thanks!
da
Aggiungi la tua risposta
Chris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 53
