Salta al contenuto principale
The Samsung Galaxy A71 is an Android smartphone manufactured by Samsung Electronics as part of the Galaxy A series. It was released in January 2020. Versions: SM-A715F/DS, SM-A715F/DSN (Global), SM-A715F/DSM (Russia).
Is this what is causing my a71 not to work?
The ribbon cable is ripped is this causing the phone not to charge ?
Edit: here is a less blurry image
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Malek Hussien your picture is very out of focus, so it is impossible to make out what you are wanting to show us. Yes, that broken ribbon cable could be the issue. You will have to replace it to fix it.
Punteggio 0
3 Commenti:
i wil post a picture with higher quality in a second
da
That won’t affect the phone working. That’s just an antenna and what’s missing won’t affect anything. Need more on the phone before you opened it up.
da
Malek Hussien @strongbow is correct. This image (thank you for reposting) shows the antenna flex. That will not stop your phone from charging. What else have you checked? How did this flex get damaged?
da
Aggiungi la tua risposta
Malek Hussien sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 113
