Salta al contenuto principale
TVmodel: LD4655VX, LED backlight, 46"
HDMI Ports Not Working w/ Amazon FireStick
No Connection to HDMI Ports on 46 in HDTV Westinghouse.Amazon Firestick is not displaying anymore I switched to HDMI 1, HDMI 3 & HDMI 2 was not connecting. Now, none of the HDMI ports are even connecting to the Amazon Firestick. No display is showing of any tv shows or programs. Blank screen!
Questa è una buona domanda?
Punteggio 1
1 Commento:
Do the ports work with any other HDMI source?
da
Aggiungi un commento
1 Risposta
The HDMI cable you're using might be malfunctioning or too old to perform adequately. Try a different HDMI cable to see if it solves your issue. Alternatively, you can use the first HDMI cable to connect a different video device to check if the video device is malfunctioning.
Regards,
Will
Punteggio 0
Aggiungi la tua risposta
JesusChristisLord GodIsGood sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 205
