Salta al contenuto principale
Repair guides and service information for the Craftsman Air Compressor. It is a power tool manufactured by Craftsman, in which power can be converted into potential energy. Model number: 919.152145
Why is it not powering on?
Just got the compressor when I turn switch and nothing happens
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@tonton69, First, use a lamp or something and plug it into the same power outlet to make sure there’s power there. If the lamp lights up, then move further.
These compressors are oil filled, and some have a low oil level cutoff switch. Did you buy it new and took it out of the box yourself? The compressors don’t come with oil, it needs to be filled to the correct level with compressor oil (not any other type of oil!).
Punteggio 1
Aggiungi la tua risposta
Anthony Firman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 247
