Where is the battery gas gauge temp sensor located?
Hi,
I have a 2020 MacBook Pro M1 that works absolutely fine. Every so often however the fan spins up to max RPM with no load on the system. I've installed Macs fan control and I can see that when this happens the 'battery gas gauge' sensor is reporting no reading.
As I say, the laptop is otherwise working just fine and I can actually turn down the fan manually with Macs fan control (albeit to 1000rpm not 0) but I'd like to know where the gas gauge sensor is located so I can try giving it a clean with some isopropyl alcohol.
Many thanks,
Ben
Questa è una buona domanda?
