Salta al contenuto principale
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Domande Visualizza tutte
How to check power supply generated voltage
Current state:
Zero LED lights up when start up attempted. Supply voltage into PSU shows 120V. If I plug a device into USB it doesn't charge.
I lean towards the PSU being defective, however, I'd like to make sure by measuring the outgoing voltage. Anyone knows which pin is supposed to show what voltage?
Thanks a lot.
Questa è una buona domanda?
Punteggio -1
3 Commenti
What is the last 3 characters of your serial number so we can determine your exact machine?
da
Sorry, I thought the system would post the device details I entered when setting the question up ...
EMC#: 2118
Ser#: xxxxxxxxVUV
Model#: MA589xx/A
da
Apple iMac "Core 2 Duo" 2.16 20-Inch Specs
Identifiers: Late 2006 - MA589LL - iMac5,1 - A1207 - 2118
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
See if this pinout will work for you: http://pinouts.radio-electronics.co/powe...
Punteggio 5
3 Commenti:
Thanks.
So if the voltage between between ground and grey wire is not as per the link, the PSU can be considered 100% faulty. Correct?
da
BTW, visually the PSU looks fine, with no capacitors leaking, nor bulging.
da
Capacitors are not the only thing that can go bad in a PSU. True they are one of the more common things. PSUs can have all the correct voltages but not be able to handle the current load of powering up. LED 1 runs off a trickle charge and basically says that the system is plugged in and the PSU has power. LED 1 should be lit all the time if the system is plugged into a working outlet of the correct voltage. If you have no LEDs your power supply needs replaced.
da
Aggiungi la tua risposta
mxs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,560
