Salta al contenuto principale
Tradizionale controller wireless per videogame prodotto da Nintendo per il sistema Switch. Numero modello: HAC-013.
88 Domande Visualizza tutte
How to remove completely stripped screw?
So I stripped the screw to the point where it’s just a round hole. I tried superglue and it didn’t work, so the hole is caked with the stuff as well. How can I remove this screw? I presume I would need a drill, but what kind of drill might work for the controller?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi
If it’s in a hole carefully drilling the screw head then removing what’s left with pliers is probably you best option
It it wasn’t in a hole you might be able to cut a slot into it for a flat head screw driver to go in into but this is probably not the best option for you
You could also try using a rubber band on the end of you screw driver
Hopefully this helps
Any questions please ask
Punteggio 2
Risposta Più Utile
C K, this is only to complete the excellent answer by @hellomacos; You could try these precision screw extractors.
I’ve had good success using those, in many cases.
Immagine Precision Screw Extractor Set
Prodotto
$24.99
Punteggio 3
Aggiungi la tua risposta
[deleted] sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 139
Tutti i Tempi: 2,512
