The system won't on even after removing the battery , please could be
My Lenovo T430, is not coming up even after removing the battery. Please what could be the issues and solution.
Questa è una buona domanda?
Here are the troubleshooting steps suggested in this support link:
Plug the PC in to power first. If that does not work, wait 5 to 10 minutes in case the battery needs to charge to a certain level.
Check the power, adapter, and cables:
Verify that the AC power adapter is correct for the system (check the user manual, How to find and view manuals for Lenovo products - ThinkPad, ThinkCentre, ideapad, ideacentre).
Plug the AC adapter into the computer and a power outlet. If the computer has a power indicator light, check if the light comes on.
Do not use a power bar, power strip, or other power extending device.
Make sure the AC adapter is securely plugged in to the computer and the outlet.
Try a different power outlet.
Does the PC make a sound (for example, fan noise). If so, check light settings and increase the brightness level.
If this doesn't work, you may try a hard reset (remove the battery and press and hold the power button for at least 10 seconds).
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 16
Tutti i Tempi: 162
