Salta al contenuto principale
Il mouse Anywhere Mouse MX è un mouse laser rilasciato da Logitech nel 2009. Il mouse si collega tramite un ricevitore Logitech Unifying ed è alimentato da due batterie AA.
Mx anywhere mouse side rubber adhesive
Hi there, just trying my luck - my Logitech anywhere 2 mouse is working perfectly, but the rubber adhesive on the side has come off so I tried to glue it back on and reallyt stuffed it up. (Cosmetically) do you repair the adhesive by anychance? Thank you Sean
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
seanhunt1988, I recently repaired a Logitech MX Master (1st gen) and I reused the old “rubber”. I did use isopropyl alcohol and tried to remove some glue, then I glued it back using some strips of very! sticky double sided tape (2mm width), meant for mobile repairs.
That tape is incredibly durable and it’s also very, very thin, which allows for the rubber to place like originally.
The one I use isn’t sold by iFixit, but it’s all over Amazon mobile tape.
Punteggio 1
Aggiungi la tua risposta
seanhunt1988 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 22
Tutti i Tempi: 1,305
