Salta al contenuto principale
Il decimo telefono di Samsung della serie top Galaxy S, lanciato a marzo 2019. Dotato di Android 9.0 (Pie).
device charges very slowly with third-party cables
My S10 charges very slowly with third-party cables, it happened suddenly 2 days ago and now my phone takes 5 hours to charge completely, I can use the fast charging only with well fitting cables like my mothers official xiaomi cable (it makes a click sound and is very sturdy). Is there a way to fix this? I know the 3rd party cable is good enough because it works perfectly on my father's s10
PS: if it can help, my battery is equivalent to 2500 mah after years of use (according to accubattery)
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@smollphotograph number one rule would be, do not use aftermarket cables or chargers. Most of those are of such inferior quality , that they can actually cause damage to your device. Yes, seems like such a minute thing, until it destroys the charging circuitry of your device. If you ever have a chance, use an oscilloscope and connect it to an aftermarket cab;e/charger. You'll see a lot of "dirty" spikes etc. Use a good quality cable made for your device and see if that makes a difference.
Punteggio 0
Aggiungi la tua risposta
Yasin-Ali Gunes sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 131
