Salta al contenuto principale
Repair and disassembly information for the first generation of Apple's high-end wireless earbuds. Released in October 2019. Identified by model numbers A2084 (left earbud), A2083 (right earbud), and A2190 (charging case).
Why are my airpods pro have a buzzing sound
When the volume is set to mid they are starting to make a buzzing
Questa è una buona domanda?
Punteggio 4
1 Commento
The left ear one had a buzzing sound and I tried everything. Finally out of frustration I slammed it into my wall. And since than it has been working well.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Could be a defect, a pairing issue, wireless interference between the AirPods and the iPhone or other nearby wireless devices, or even a certain app generating bad sound. If this happened to me, I'd try force quitting the app in question and/or unpairing and re-pairing the AirPods.
Regards,
Will
Punteggio 0
1 Commento:
I found out that they weren’t original even though I bought it from bestbuy and they were harmed inside so I returned them. Thx though for your advice
da
Risposta Più Utile
a batch of 2019 models produce a hissing or static noise when using ANC. this issue cannot be fixed. get a replacement while in warranty else either discard and get next generation.
some 2020 batches also have the same issue but apple wont replace them saying it doesnt belong to 2019 batch.
each bud costs $89
Punteggio 1
4 Commenti:
same here… bought in 2020… right airpod has that problem…
tried to cange it wirhin warrenty… decliend… now they are out of warrentie… and they can only be used without anc/ transparency mode :(
da
Same here. 😭
da
if i wanted to repair this issue myself what part would i need buy to replace?
da
@subarujusts8628 I have the same problem, I found a product like "Top Housing Case With Noise Reduction Microphone" on aliexpress. maybe this product contains the parts needed for repair?
da
Aggiungi la tua risposta
Horia Martin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 94
Ultimi 30 Giorni: 502
Tutti i Tempi: 24,872
