Salta al contenuto principale
Tradizionale controller wireless per videogame prodotto da Nintendo per il sistema Switch. Numero modello: HAC-013.
Motherboard is missing a component which stopped battery from charging
I was installing a new potentiometer and I accidentally knocked off a small piece off the board, the part is labeled UP0KC or UPOKC I'm not sure which, but there's a picture of it. I'd like to know where I can find it and if I can't find it how it works and if I can bypass it.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
You could bridge cables if you know how to solder properly like tronicfix or you’d have to get a new fuse somehow
Punteggio 1
4 Commenti:
It's a Fuze then?
da
And if I were to bypass it how would I do that considering it's 2 prongs to 3.
da
Ah never mind over more carefull inspection of the image it looks as if its a smaller chip
da
And im not sure if it can be bypassed like so you’d probably have to replace it
da
Aggiungi la tua risposta
Gabriel Logulo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 97
