Salta al contenuto principale
Informazioni sulla riparazione e guide per l'iPhone 8, lanciato il 22 settembre 2017. Modelli A1863, A1905.
How can I bypass the locked to owner
My Iphone is locked to owner and the previous owner is not available, is there a way to bypass it?
Questa è una buona domanda?
Punteggio 12
1 Commento
My iPhone 11 pro is lock by the owner and I don't know the owner because it's a second hand iPhone, how can you help me please?
da
Aggiungi un commento
6 Risposte
Soluzione Prescelta
Hi
Sorry but this isn’t really possible unless you do some stuff under the radar that doesn’t even fully unlock it
Your best bet is probably to contact the company or person that you bought it from any see about getting your money back as trying to unlock something from iCloud is not fun and rarely works
Hopefully this helps
Any questions please ask
Punteggio 6
2 Commenti:
how do I do it
da
So when is going to open bypass
da
short answer is no.
the icloud-to-phone association lives on Apple's servers and the only way to break it is to to remove it with the icloud account name and password either on the phone, appleid.apple.com or www.icloud.com.
doing any of the erase/reset functions will not remove it.
itunes or 3utools will not remove it.
you may see software solutions or services that say they can remove it, but they mostly involve jailbreaking the phone and doing a "workaround", but any time you power-cycle the phone, perform any sort of reset or update IOS, you will have to apply the workaround again. i have no idea how effective they are, but i don't do jailbreaks, so i wouldn't consider nay of these, plus most of them require a subscription.
anyone offering a service to remove it is probably a scam.
that said, depending on the model and configuration, icloud locked phones sell on ebay all the time.
Punteggio 2
You may be able to fully reset the phone which might remove the lock.
I use the 3U Tools program which can put your phone in either the reset mode or completely wipe it.
Hope this helps.
Punteggio 1
1 Commento:
doing an anti-recovery flash with 3uTools will update IOS, reset all settings, clear any passcode and return the phone to OOTB condition, but it WILL NOT remove the icloud account.
da
If you know your iPhone’s screen passcode and see the “Unlock with Passcode” option on the Locked to Owner(iCloud Activation Lock) screen, you can tap it and choose “Enter Device Passcode” to remove the iCloud lock.
If that option isn’t available, but you have enough proof that you’re the legitimate owner of the device, you can try reaching out to Apple Support for assistance.
Punteggio 0
I saw some tutorials on YouTube that said it can be unlocked using tools like TunesKit iPhone Unlocker. Many youtubers showed the unlocking process, but I don't know if it's really possible.
Punteggio 0
Check what your iPhone model is. If your iPhone is iPhone X or earlier, try MagFone iPhone Unlocker. If your iPhone is iPhone XR or later, unless you know the correct Apple ID and password, or looking for Apple official support, you can not unlock the iPhone locked to owner.
Punteggio 0
Aggiungi la tua risposta
Bonga Peter sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 16
Ultimi 7 Giorni: 147
Ultimi 30 Giorni: 685
Tutti i Tempi: 9,376
