Salta al contenuto principale
The Suzuki Swift is a subcompact automobile manufactured by Suzuki, a Japanese automaker. The second-generation Suzuki Swift was introduced in September 2010 and replaced with a new generation in February 2017.
I loose power when accelerating and sometimes when in traffic
Intermittent stalling immediately after starting or punching gas. Sometimes also in traffic. I have tried changing the CVT, testing sensors, What might be the issue?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Sounds like a fuel injector issue. Could also be a vacuum leak.
Punteggio 1
2 Commenti:
I have to check this...But how would I check a vacuum leak ?
da
That is difficult unless it is a big leak and you can hear it. Disconnecting or pinching off vacuum lines might give a clue, but that involves much understanding of what you are affecting. My bet is on the injectors.
da
Hi mate. Did you fix your problem?
What if your throttle was clogged?
Punteggio 0
2 Commenti:
I've fixed a clogged catalytic converter that did something like this. I drilled a 3/8" hole in it.
da
might be fuel filter also that need to be cleaned or replaced..
da
Aggiungi la tua risposta
William Afrika sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 35
Tutti i Tempi: 671
