Salta al contenuto principale
Impara a conoscere le competenze di cui potresti aver bisogno per lavorare sul tuo dispositivo.
20 Domande Visualizza tutte
What product do you recommend for removing a smartphone battery?
What product do you recommend for removing a smartphone battery sticker? I wanted to get iFixit Adhesive Remover but I saw that it is no longer available. Last time I did it through a hair dryer, but I still risked ruining the battery a bit.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi
See my answer as a extension of the amazing answer @guardian10 has kindly provided
IFixit’s adhesive remover is good but iFixits iOpener is also a great choice
A hair dryer works great too along side isopropyl alcohol
Also here’s a little tip:when prying battery’s up try your best to AVOID metal tools as they can puncture the battery if you aren’t careful
Plastic tools don’t have as high a chance of puncturing a battery but the risk is still there so it’s best to stick to the ones that are flat and don’t have any sharp edges
Hopefully this helps
Any questions please ask
Punteggio 6
4 Commenti:
Thank you very much for your advice. Everything went well, however, now I have encountered new problems.
https://it.ifixit.com/Risposte/Visualizz...
Do you have any advice?
da
@most99
Can you see any damage to the connector or cable
Also did you unplug it
da
which one in particular?
da
@most99
Sorry I should have said in the previous comment
I am wondering about the camera
da
While it is preferable to use Ifixit adhesive remover, you can use regular isopropyl alcohol to weaken the adhesive, then pry the battery up.
Punteggio 5
1 Commento:
da
Aggiungi la tua risposta
Gavino Santu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 238
