Salta al contenuto principale
Lanciato a novembre 2020, il MacBook Pro da 13" ha il SoC basato su ARM M1 di Apple con una CPU octacore e una GPU octacore. (Modello A2338 / EMC 3578 con due porte Thunderbolt 3)
MacBook Pro won’t turn on after battery disconnection
hello
i have a 2020 m1 macbook pro. i disconnected the battery and reconnected it, and now my macbook will only turn on when connect to the power adapter. also the fax runs on max when it’s on. could it be that i haven’t reconnected the battery correctly?
Questa è una buona domanda?
Punteggio 3
13 Commenti
Restart your system and press the D key to enter into the system’s onboard diagnostics, let us know what the erro message is.
da
@danj sadly i can’t get into diagnostics
da
@Majd D
For a apple silicon Mac you need to press/hold command(CMD ⌘) + D at start up/restart
That should get you into the diognostics:-)
da
@hellomacos - Yep! Had Intel on my mind. Thanks for catching that.
da
@danj
No problem
It happens to me all the time XD
da
Mostra altri 8 commenti
Aggiungi un commento
1 Risposta
Risposta Più Utile
This sounds to me like the battery data cable is not connected quite properly, or your battery is faulty. This is pretty typical of a sensor not communicating toThe MacBook Pro Battery has 2 battery connections. The first is the small cable and the second is the large T5 screw, which forces the actual power connections. I would verify the cable is seated properly on both ends, and that the little latch holding it in place is present, and closed.
Punteggio 2
3 Commenti:
that’s what i was thinking. but after making sure it’s connected dozens of times i’m not convinced i short circuited it :(
da
Hi! Could you tell me how you solved it?
da
In my case the data cable got damaged during disassembly, I ordered a replacement and that fixed it.
da
Aggiungi la tua risposta
Yyy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 28
Tutti i Tempi: 1,366
