Salta al contenuto principale
Una console portatile rilasciata da Valve. Lanciata sul mercato il 25 febbraio 2022.
Left speaker suddenly stopped working.
The left speaker suddenly stopped working and I'm outside the US so RMA would be a pain. Anyway, rebooting, doing factory reset, and installing Windows to just test audio didn't seem to fix the problem. Audio only plays on the right speaker no matter what OS. Audio via 3.55mm/Bluetooth works fine.
This started happening after waking up the Steam Deck and all I get is a crackle from the right speaker. When I rebooted, there isn't any audio playing on the left speaker though the crackling on the right speaker appears to have gone away.
Does this mean the speaker itself is broken?
I already have the speaker replacement arriving next week. Just want to make sure I'm on the right path?
Thanks for your help.
Questa è una buona domanda?
Punteggio 1
1 Commento:
Developing story: For some reason it started working again after I left it turned off for several hours.
I'm still observing but keeping the replacement speaker just in case.
da
Aggiungi un commento
2 Risposte
"all I get is a crackle from the right speaker." It sounds to me like either the cable is broken or the speaker is broken.
It could be other things, but these are most likely.
You should wait on some other thoughts/opinions too though.
Punteggio 0
mine did the same in now its getting hot on the left speaker now in melting the plastic
Punteggio 0
Aggiungi la tua risposta
Albee Dela Cruz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,143
