Card reader replaced but still not reading cartridges
Update
There certainly is a pin missing.
This problem may have begun with a bent pin, but at some point I must have knocked it loose because there definitely is one missing. See photo below:
Note: This problem is new, the Switch was new and worked for quite some time and no there where no obvious moments of dropping or damage after which it suddenly had this issue.
I began getting the error with the stock card reader on this Nintendo Switch Lite:
The game card could not be read.
Please remove and reinsert it.
If this message appears repeatedly, please check the following page on your smart device or PC.
support.nintendo.com/switch/gamecarderror
1) Oddly enough, the Rayman Legends cartridge still works, just fine. But it is the only game cartridge that does.
2) None of the other cartridges work on this Switch Lite.
3) All other cartridges work on other Switch Lites and our Docked Switch.
4) Downloaded games still work.
So I ordered a replacement card reader and just installed it. No change. The issue persisted.
But I noticed during the processes that the original card reader ribbon was notched by some sort of pressure from the mount. I've included a picture.
I installed the new card reader, connected the ribbon, and then took it back out. There's a slight impression, hardly noticeable in the new one.
I used a magnifying glass to observe the port, there is no obvious damage or debris, though there is a gap in one of the nodes (picture included) but I am not learned enough to know if that is a defect or abnormality to begin with.
I'm curious if anyone has replicated this issue or heard of what might be the problem on the Switch side. I doubt the brand new card reader would have the same problem (bought it straight from ifixit).
Questa è una buona domanda?
