Salta al contenuto principale
The Acer Chromebook 14 (CP5-471-C0EX) is a Chromebook released by Acer on May 31, 2016 as an enterprise focused device powered by a 6th Generation Intel Core i3-6100U with a base clock speed of 2.3 GHZ.
Why won’t my computer connect while setting up?
So I just got this Chromebook and it has been doing this for almost 2 hours, how do I fix it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Check your Wi-Fi settings
Check the Wireless Mode setting for your network adapter and make sure it matches the capabilities of the network you're trying to connect to. If it doesn't match, you won't be able to connect, and the network might not appear in the list of available networks.
Regards,
Will
Punteggio 0
Aggiungi la tua risposta
Haaken peterson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 105
