Salta al contenuto principale
Modello A1311 / Metà 2011 / Processore Core i5 da 2,5 e 2,7 GHz o Core i7 da 2,8 GHz
432 Domande Visualizza tutte
iMac Black Screen No Chime Led 1 Fans Rev
Hi There.
I have a problem a back screen issue.
The fans turns on with the hdd and DVD drive.
I checked the onboard diagnostics and LED 2, 3 and 4 are off.
I have replaced the PSU but but still a black screen.
I have replaced the cmos battery but still black screen.
I have baked the gpu but still black screen.
Ask for any info about Imac.
Edit.
I forgot to mention I plugged in a different keyboard when it was working and when 15 min past it crashed and I could turn it on but it would crash less then 10 min in it would crash. The next day it would not turn on I have the issue now.
Update (01/08/2023)
@danj
This is the gpu
Update (01/08/2023)
The specs
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sounds to me Like A Scary failed logic Board Or CPU!
Take it The board out and look for any corrosion,
And Check The CPU
Guide: Installazione della scheda logica nell'iMac Intel EMC 2428 da 21,5" iMac Intel 21.5" EMC 2428 CPU Replacement
Immagine iMac Intel 21.5" EMC 2428 CPU
Guida
Difficoltà:
Difficile
3 - 5 hours
Immagine iMac Intel 21.5" EMC 2428 Scheda Logica
Guida
Difficoltà:
Difficile
1 - 4 hours
Punteggio 4
61 Commenti:
da
Hmm... I'd say try reseating the CPU.
da
@beanman56
It didn't work I reseated the CPU. Still doesn't work.
da
@tomytom - Okay sounds like a faulty logic board then...
@oldturkey03 - Any thoughts?
da
@beanman56 - Often I find the GPU power rail is shorted to ground. Inferring a short with in the GPU board likely a burnt cap.
da
Mostra altri 56 commenti
Aggiungi la tua risposta
tomytom sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 487
