Salta al contenuto principale
Guides and repair information for vehicles made by SEAT.
Engine noise from 2011 Seat Leon
I have a 2011 1.6 Litre Seat Leon Diesel. The engine has been louder than usual and there is a vibrating when sitting in the car. The vibrating is worse when the clutch is depressed. Does anyone know what could cause this?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
@johndoe177 this "The vibrating is worse when the clutch is depressed" could be a bad bearing or a worn pressure plate. Check your clutch a bit better and see if the noise sounds more like a grinding coming from the clutch area. Of course it could also be a vacuum leak as well as 100 other things that may cause your engine to develop a vibration. Consider having the OBD scanned to see if it throws a code.
Punteggio 4
If you push acceleration and the the noise go away, it may be a flywheel.second thing the clutch pedal may biting foot on a half way.But if the pressing clutch influence on noise you must take of gear box anyway, the you will see the problem
Punteggio 0
Aggiungi la tua risposta
John doe sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 82
Tutti i Tempi: 1,486
