Joy-Con (R), bent pin in bottom ZIF ribbon cable connector
I replaced the ribbon cable in my right joycon. In the process, I damaged the bottom ZIF connector where the ribbon cable attaches.
I could still attach the cable, and the joycon did work. However it failed to detect that it was connected directly to the Switch. The controller would charge, but it showed up as detached.
On closer inspection one of the pins in the ZIF connector was clearly bent.
I was able to manually bend the pin down. While it's still bendy compared to the other ones, it isn't sticking up anymore. After re-assembling the joycon, it detects being attached to the Switch, and everything appears operational.
Two questions:
1) Is there any way to replace the ZIF connector?
2) Is it dangerous to use the joycon with a bent pin like that?
Questa è una buona domanda?
