Salta al contenuto principale
After switching on device all three temperature indicators started bli
After switching on device it heats up while and all the temperature indicators started blinking.
Still straightener keeps on heating, but temperature level couldn't be identified as all three indicators are blinking
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Your Steampod flashes due to a component failure. In the majority of cases, it will be a failure from one of these elements:
  • the resistance of the plates
  • the electronic card
  • the thermostat
  • Before moving on to hardware repairs, remember to check that there is enough water in the tank flashing Steampod straightener. Indeed, if it lacks water, it may not be able to reach the requested temperature and therefore it signals you by flashing. Also check that the hair straightener is not in energy saving mode. Indeed, the device goes into standby after 1 hour without manipulation. If you try to turn it on without having reset it, then it may start blinking and not turn on. To reset the Steampod, you just have to long press the on/off button.
Punteggio 2
2 Commenti:
Muy interesante la respuesta de nuestro compañero Mayer, la traduzco a Español:
Tu Steampod parpadea debido a un fallo de un componente. En la mayoría de los casos, será un fallo de uno de estos elementos:
la resistencia de las placas
la tarjeta electrónica
el termostato
Antes de pasar a la reparación del hardware, no olvide comprobar que hay suficiente agua en el depósito que parpadea la plancha Steampod. De hecho, si le falta agua, es posible que no pueda alcanzar la temperatura solicitada y, por lo tanto, le avise parpadeando. Compruebe también que la plancha de pelo no esté en modo de ahorro de energía. En efecto, el aparato entra en modo de espera después de 1 hora sin manipulación.
Si intenta encenderla sin haberla reseteado, puede que empiece a parpadear y no se encienda. Para reiniciar el Steampod, basta con pulsar prolongadamente el botón de encendido/apagado.
da
Translated
Here are the answers to the new compañero Mayer, the course in Español:
This Steampod part appears on one component. In the city of Los Angeles, there is a fall in one of these elements:
The resistance of the places
The tarjeta electrónica
the thermostat
When the hardware is repaired, no components are installed that have been used in the repair of the Steampod plan. Hecho, si le falta agua, es possible que no pueda alcanzar la temperatura solicitada y, for lo tanto, le avise parpadeando. Comprue be sure that the plancha that is next to the energy mode. Effectively, the next step in the mode of operation is removed 1 hour after maintenance.
If we intend to reset the device, then this item should be removed and not sent. To replace the Steampod, use the pulsator to extend the bottom of the original/apagado.
da
Aggiungi la tua risposta
Muhammadbilal Pathan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 82
Tutti i Tempi: 3,413
