Can MG 8331S be soldered on?
I am planning to purchase the MG 8331S to repair my burnt battery connector area. Currently, the vias are exposed and I'm planning to use normal epoxy to patch the areas around the vias before using the silver conductive epoxy.
However, I'm not sure if the MG 8331S can be soldered on after curing. A previous answer says it can be (Anyway to reattach solder pads?) while other forums and some 8331 products' datasheets it can't.
Thank you in advance.
Edit1: General area.
Edit2: Battery Clip Connector Component (board side - female)
Location on board:
Edit3:
(Flipped over the connector)
Questa è una buona domanda?
