Salta al contenuto principale
La versione con solo il Wi-Fi dell' Apple iPad Air, numero modello A1474. Disponibile nei colori grigio siderale e argento, ha un processore A7 custom ed è disponibile con memoria da 16, 32, 64 o 128 GB.
error 4042 during DFU software restore
what is the solution for ipad air problem with 4042 error during DFU software restore?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
I had the same problem. Screen was black until i plugged it into a charger from an outlet, then logo kept going on and off. Tried all teh fixes to reset and restore through itunes, but nothing worked. I found a little info on what could cause problems with an iphone rebooting and took a guess that it was the battery. Had the battery replaced and it's fixed. I checked a few forums and also called some cell phone repair shops, was told: it's the phone gone bad, it's the circuit board, it's the software. I took it to the repair shop and told the guy it I thought it was the battery. He said is was a chip, but would humor me and replace the battery to prove it wasn't the battery. Turns out, it was. It cost me $25 to get the battery replaced on an iphone 6S, but prices can vary greatly depending on the repair shop, so I'd do some calling to find out what it costs to replace a battery on your device before you decide on which shop to visit.
Punteggio 2
2 Commenti:
thank you!! it was the same thing with my iphone, god bless you lol
da
Thanks to reading these 2 comments above, you saved me from having to buy a new phone today! I had the same issues, nothing I tried doing online to restore my iPhone 11 worked. I decided to try replacing the battery first as a form of process of elimination, and BOOM it worked... I came across these messages completely by accident, but Im so glad I did, thank you!
da
I had the same issue. Suddenly my iPad wasn’t charging properly. It was restarting every 2 seconds. Brought it to the Apple Store to have it checked. Battery was ok. But they couldn’t fix it (hardware issue) and offered to buy a new unit.
I ended up buying a new unit but didn’t gave up on the old one.
I brought it to someone doing micro soldering and upon opening it he found out that some component of the charging board had to be replaced. It did the trick. Cost me 159€. ;)
Punteggio 0
Aggiungi la tua risposta
Ino Depone sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 15
Ultimi 30 giorni: 79
Tutti i Tempi: 15,088
