Salta al contenuto principale
Lo smartwatch Apple di quarta generazione, con connettività cellulare opzionale, lanciato il 21 settembre 2018.
Which lcd adhesive to use
I will be replacing the battery in my series 4 and wanted to confirm the best adhesive to use when sealing the lcd back into the watch keeping full waterproofing still. I've seen people use b7000 or you can buy the precut tesa tape but I was told cold press glue is the best thing to use?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Use the recommended adhesive strip:
Apple Watch (44 mm Series 4/5) Screen Adhesive
Immagine Replace an adhesive strip compatible with the 44 mm case Series 4 or Series 5 Apple Watch model A1976, A1978, A2008, A2093, A2095, and A2157.
Prodotto
$6.99
Punteggio 3
B7000 should work just fine, but make sure to wipe off any seepage before letting it dry.
Punteggio 2
2 Commenti:
The watch will still be fully waterproof after using b7000?
da
@ntec No, you shouldn't trust anything underwater after they have been repaired. If you want a bit more peace of mind, use the product in the answer from @mayer, but don't put it in water.
da
Aggiungi la tua risposta
John Nguyen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 498
