Salta al contenuto principale
The first generation Forte shares the same platform as the Hyundai Elantra (HD), though employing a torsion-beam rear suspension in place of the Elantra's multilink design.
Is it harmful for the engine to use tiptronic transmission
I almost always use tiptronic transmission in my car to lower fuel consumption but it doesn't change to gear 5 even my speed is more than 100 km per hour is there anything wrong i have to check ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It's not harmful, but it's pointless. Automatics are programmed to shift to maximize efficiency.
Does it shift into 5th and 6th gear in automatic mode?
Punteggio 1
كيف اقوم بصيانة ناقل الحركة الاتوماتيكي لان عند وضعه علىd لاتتحرك السيارة وعند وضعه علىr تتحرك السيارة للخلف
Punteggio 0
1 Commento:
السلام عليكم كيا فورتي موديل 2008 ناقل الحركة الاوتوماتيك لا يعمل بشكل صحيح لا تتحرك السيارة الى الامام وتتحرك الى الخلف
da
Aggiungi la tua risposta
Abdullah kamar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 290
