Sony Vaio Battery Screws
Lost the two screws holding my battery in. Your site says they are 11mm. I assume that is the length. What is the diameter and pitch?
Questa è una buona domanda?
Hi
Sorry but I don’t have a laptop to check but I have a solution!
From what the other guides show ,they all look to be roughly the same so I would measure the other screws on the bottom and check to make sure they fit the battery’s slot holes and order them accordingly
Hopefully this helps
Any questions please ask
I tried that before asking for help. The other screws are all too small or too short. I took the laptop to the hardware store and found the closest metric fit to be 2mm by 0.4 pitch by 12mm. But even it was a little wobbly. But they are holding. I placed electrical tape over them as they stick up a bit and will scratch.
Have you considered buying a box full of screws and sewing which ones work best?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 97
