Salta al contenuto principale
Processore dual core Intel i7 da 2,2 GHz (Turbo Boost fino a 3,1 GHz) o quad core Intel Core i7 da 2,5 GHz (Turbo Boost fino a 3,7 GHz) con 6 MB di cache L3 condivisa.
Bottom row of the keyboard is not working
Was trying to replace my speakers, but when I turn it back on, only the bottom row is not working. Only "Left Command + ZXCVBNM" are not working. Anyone know what's causing it? Which part did I break?
Thank you all!!!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Jump back to Step 23 in the Sostituzione altoparlanti MacBook Pro 15" Retina Display Mid 2014 guide. Make sure the cable is squarely seated and the latch is properly set. Often I see the cable at an angle or not fully inserted, or not compressed by the latch.
Punteggio 1
2 Commenti:
Yes I did that couple of times... is there any other issue that might caused it in your experience? Was working before I opened it.
da
@timtwo - Could you have damaged the cable?
da
Aggiungi la tua risposta
Tim sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 238
