Salta al contenuto principale
Il Mi 11 è un telefono al top della gamma Xiaomi dotato di schermo AMOLED da 6,81" a quadrupla curvatura, fotocamera principale da 108 MP, sensore impronte digitali integrato nello schermo e batteria da 4600 mAh. È il primo telefono dotato di Qualcomm Snapdragon 888 e si basa sull'interfaccia MIUI 12 su Android 11.
Does anybody know this part?
Hello guys,
i need the part from the picture to repair my Mi 11 Ultra... it's a metal bracket / clip wich hold's the flex-cabel from the back-display on the mainboard. Does anybody know what's the exact name for this part, or can someboy tell me where i can buy it!?
Kind regards,
David
Update (09/15/2022)
I have found it, thanks guys!!!
If anybody need's the same part, here it is:
https://www.aliexpress.com/item/10050047...
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
My educated guess is that this is the battery connector bracket. Mi 11 Screen Replacement guide has a similar part that is shown in step 9. I can't seem to find a place that sells it specifically, but I would be willing to bet that you could find it if you search eBay.
Punteggio 3
1 Commento:
Thanks for your information! Now I know the connector type is called "fpc" and I can search for it. Do you think it's possible to glue the connector on the mainboard or to stick it with a heat resistant tape?
da
It's a clip to hold the fpc connection in place. As long as the connection is seated properly you could get away without it if you can't find another. Through normal use the connector shouldn't move unless the phone suffers a heavy drop.
Punteggio 3
Aggiungi la tua risposta
Kuki sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 596
