Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
White screen, multi coloured lines and Odd short sound
I have an iPhone 3gs 32Gb and suddenly it went off and wont turn on. When i try pressing power button, multi colored lines appear and after a few seconds phone just switches off. When i use the hold button, it vibrates and when i switch the hold button again, it vibrates again. When I connect it to the PC, a sound is heard, white screen appears and iTunes detects phone and says newer version available. then suddenly phone gets disconnected and phone goes off again. Need help. How do i fix this?
Questa è una buona domanda?
Punteggio -1
4 Commenti
Yea Nick. The problem was the screen. just put a new screen and the phone works like magic :P
da
loose or bad?
da
Bad. Now I have a new problem. Since its a jailbroken phone, suddenly for some reason, the IMEI, bluetooth and wifi are blank. :O. Anybody know what exactly is wrong?
da
try a restore, it could be bad software and re-jailbreak it
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Try reconnecting the screen to the logicboard
If that does not work, it is the screen
If the issue is not solved with a new screen, it needs further troubleshooting
Punteggio 2
Aggiungi la tua risposta
Prarth sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,072
