Salta al contenuto principale
Lo smartphone top di gamma di Apple per il 2021. Lanciato sul mercato il il 24 settembre, l'iPhone 13 Pro Max ha uno schermo OLED ProMotion da 6,7 pollici, un nuovo sistema di fotocamera tripla posteriore e connettività 5G. Successore dell'iPhone 12 Pro Max.
Torn cable on back of board
I accidentally ripped a ribbon cable on the back of my board when removing. What does it go to and is there a way to fix it if it’s critical?
Questa è una buona domanda?
Punteggio 0
6 Commenti
Wish I'd seen this in Apple's manual or elsewhere before I ripped it.
da
Has this been solved and if so how do i do it? mine just tore while trying to replace a broken flashlight
da
mine broke too. Please let us know what this is for
da
I wish I'd seen this in Apple's manual or anywhere before I ripped it.
da
OMG finally I found a post that's related to the same issue I'm having. Although I have the iPhone 13 with a flex cable underneath it.,after following the flex cable it runs along the wall of the power an volume buttons but it was connected to a connector attached the wall.,to me as of now it looks like it could be an antenna an if it is does it really have any play with the board besides needing to connect to any wifi connection.
da
Mostra 1 altro commento
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I haven’t seen this on a 13 pro yet but I have on the 12 pro. What you have circled is actually an IC for the antenna and it is soldered to the board, the flex runs down to the bottom of the board. I think the phone should still boot but I am not sure about the implications of cell functionality.
I think at the moment since this model is new you would need to get a donor board and de-solder the IC and transfer it to your board. It will require microsoldering and a lot of skill as I don’t think there will be any alignment marks to line it up when soldering.
Punteggio 1
1 Commento:
Where can you get the part from?
da
Risposta Più Utile
Pop the black connector off that's still on the board. Post a pic of the torn ribbon in the phone. It could be the ribbon for the power button.
Punteggio 1
1 Commento:
That black connector is soldered to the board
da
Aggiungi la tua risposta
spencerhcovert sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 45
Tutti i Tempi: 2,018
