Phillips 2.0 × 2.5 screwdriver, which ifixit kit has it
Hi, I don't understand what Phillips 2.0 × 2.5 means besides it's a Phillips screwdriver. I am trying to remove the ram from a HP zBook 15 fury. Thank you!
Questa è una buona domanda?
@wilmalee2 I believe that would you are reading as "Phillips 2.0 × 2.5" is actually Phillips M2.0 × 2.5 which means its a 2mm thread and the screw is 2.5 mm long (thread length). With a 2MM screw your screwdriver is most likely a PH 0 or PH1 The Minnow kit Minnow Driver Kit will have those as well as all the other kits. If you do more work on computers/electronics go for the big guns. Pro Tech Toolkit Those kits are all awesome.
Hi I have the Pro Tech Toolkit and those don't work for some reason. It's like it won't latch on to the screw. :(
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 309
I talked to HP support and they say Magnetic Phillips P1 screwdriver. I guess the ifixit tools are not magnetic?
da Wilma Lee
@wilmalee2 not sure why the magnetic would make a difference but no, they are not. Get a small fridge magnet and attach that to the driver to make it magnetic.
da oldturkey03
