A big thing nobody mentions is ear wax!
It gets absorbed in the foam eventually blocking a significant amount of noise and fidelity, so you turn it up, which drains the battery significantly faster.
Use a toothpick, pull out the foam a bit a couple of mm, squeeze till clean with a tissue.
Be careful not to pull it all the way out or tear it as Sony is shocking for replacements, so are all Bluetooth ear bud companies. Don't compact the foam down, this will also block sound.
Damaged tips also let out sound, you can replace these but super pricey.
Keeping them clean can preserve the life of the battery as well as prolonging the need to replace it.
A repairable ear bud should have cheap and easily replaceable batteries, tips and foam. When one exists I'll buy it.
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
4 Commenti
Is it under warranty for Sony service or repair? Check Sony's website for FAQs (battery life of container and ear buds, number of charging cycles, etc). Are electrical contacts free of debris?
da F Dryer
I am having this issue as well, though mine starting dying just a year after purchase. Conveniently outside of warranty. Apparently this is a well known issue with these buds which Sony is doing nothing about. Doing some light research allowed me to find dozens of similar cases where just after warranty they essentially die.
Sony service essentially said I'm out of luck. I can pay to ship them in and have them repaired or buy a brand new pair.
If anyone knows where to get batteries and how to replace them in the earbuds and charging case that'd be fantastic. Other than the battery issue these are great buds and I'd like to not have to replace them.
da Tylor Branch
Does this help? https://www.youtube.com/watch?v=JZp8pSDY...
da F Dryer
This video gives a more comprehension guide as well as the batteries needed.
https://www.youtube.com/watch?v=x2twbzht...
da inPHAMEus
