Why is the replacement screen going black?
I replaced the screen because it had started to flicker and then didn’t work any more.at all. It happened after an iOS update but Apple said the software is not the problem, the screen needed replacing.
After replacing the screen using the iFixit part and guide (and replacing the battery at the same time) it now goes black 3-5 times a day. The iPhone is still on, I can hear clicks when pressing the screen. After a force restart the screen works for a while. That seems to indicate it’s not a faulty connection. FaceID doesn’t work since my screen replacement, I probably damaged the parts (this was my first screen replacement)
What now? Thanks for your help.
Questa è una buona domanda?
2 Commenti
you maybe damaged the proximity sensor flex, its on the part that you swap from the old screen to the new screen
da daniel
thanks for the comment
da Matthias Schneider
