Salta al contenuto principale
Xbox One S, progettata da Microsoft Corporation, è stata rilasciata ad agosto 2016. Xbox One S è una riprogettazione di Xbox One.
Boots into error menu and offline update fails
I got this xbox one s from my friend in this state. It powers on into the startup error menu with E203 . I then proceed to offline update it and it gives me E101 immediately after starting. I haven't seen any solutions to this anywhere else so I thought I should ask it here.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Good afternoon from Australia,
Have you tried googling this? If not then maybe try looking at other places.
Based on what I have seen, replacing the hard drive might be a good idea as it could be a faulty hard drive (You never know)
da
Thanks I'll try it
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It turns out the hard drive was bad. I replaced it, performed the usb update, and it worked. Thanks for the help!
Punteggio 0
Hi,
There are a few things you could try
  1. resetting the Xbox to factory defaults
  2. downloading the update on a USB and installing offline https://support.xbox.com/en-GB/help/hard...
  3. Replace the hard drive
If I were you, I would try in that order and hopefully 1 should get you to the bottom of it
Punteggio 0
Aggiungi la tua risposta
Wyatt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 610
