Salta al contenuto principale
The DeLonghi ESAM family of products is a line of automatic coffee machines for making lattes, cappuccinos, espressos, and other drinks. Look for the model number ESAMxxxx on a sticker on the back or bottom of the device.
Delonghi Caffe Corso Flashing Water Tank Error
Hello, my Caffe Corso worked fine until a few weeks ago when it stopped making coffee. I took the entire thing apart water pipes, pump, valve etc. and found the primary issue - a huge rock of limescale clogging one of the smaller pipes - and removed it. Water now flows, however, only for circa 10 seconds and suddenly it cuts out with the water tank light flashing. I can try again and it will work but again, only for circa 10 seconds. Does anyone have any ideas aside from the usual one of turning the steam nob because this only works for 10 seconds too. For the same reason, it cannot be properly descaled, although I've manually ran this. Thanks!
Questa è una buona domanda?
Punteggio 1
1 Commento:
Did this tips helped out...I also have this problem
da
Aggiungi un commento
1 Risposta
Have a look for the flowmeter. There is a guide for the ECAM series, the flowmeter for ESAM is the same.
DeLonghi ECAM Series Flowmeter tauschen/revidieren
(In German, use Google translate)
The test mode could bei helpful:
DeLonghi ESAM xxxx - Testmodus
And: there is a "finger" on the rear side of the drip tray. If it is broken, the machine does not "feel" the closed tray.
2nd and: worst case: a clogged heater...
Immagine DeLonghi ESAM  xxxx - (Different Types)
Guida
DeLonghi ESAM xxxx - Test Mode
Difficoltà:
Moderato
Immagine DeLonghi ETAM Series Replace/revise flow meter
Guida
Replace/revise DeLonghi ECAM Series flow meter
Difficoltà:
Moderato
Punteggio 0
Aggiungi la tua risposta
Lewis Bateman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 39
Tutti i Tempi: 1,246
