Can you use it with a disconnected home button?
Can you still use it with a physically disconnected home button.
Of course you will lose Touch ID but can you use it just like a bezel less iPhone?
Questa è una buona domanda?
The newer iPhones without a home button use a much different set of gestures to operate the functions that a home button used to provide, and those gestures are not available on a phone that comes with a home button like yours.
However, it does have the ability to provide an on-screen virtual home button using the Assistive Touch function that gives you most of the functions of the home button on-screen. MacRumors has a good write-up on how to set that up here.
How to Create a Virtual Home Button in iOS Using Assistive Touch - MacRumors
If I'm not mistaken, about the only thing you won't be able to do with the virtual home button is a hard reset; that requires a physical button, but for most everything else you should be able to get by with a disconnected button using the Assistive Touch button.
Hi
I believe you can use it without a home button but you won’t have any home button functionality or Touch ID
You can get some functionality back by turning on assistive touch
Hopefully this helps
Any questions please ask
lol, @hellomacos, you beat me to the answer - again! I'll leave mine up with the directions for setting up the assistive touch though. As always, thanks for your help.
Haha,sorry about that XD
Thanks for adding the directions for assistive touch
I cant leave you without so Il give you a vote up:-)
Thanks too for all the help you have provided on this amazing community:-)
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 54
