Salta al contenuto principale
Informazioni sulla riparazione e sullo smontaggio dell'Apple Watch SE di prima generazione, annunciato il 18 settembre 2020.
33 Domande Visualizza tutte
Digitizer touch glass from series 5 works on SE?
Hello, I have successfully separate the glass from the display I damage the touch in process so I had to take out the touch , the question is the digitiser from Apple Watch Series 5 works on SE?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi
Iv had a look at some replacement parts and from what I have seen it should work because most of the parts I looked at were compatible with both the SE and the series5
What I would do to be sure is use a replacement part that says it’s compatible with both just to be certain;-)
Hopefully this helps
Any questions please ask
Punteggio 2
Yes, it works! i just swapped and SE screen to an S5 LTE and works.
Punteggio 0
Aggiungi la tua risposta
Stelios K. sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 278
