Salta al contenuto principale
A1708 / EMC 2978 — Lanciato nell'ottobre 2016, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED). La versione function key adotta l'Intel Core i5 e 2 porte Thunderbolt.
Display cable torn causing pink screen
Hi,
We replaced the screen for a customer in Feb 21 on their A1708. This week they messaged saying that they had a pink screen. I replied with steps to try and resolve the issue and suggested if that didn't work to take it a local company we know well who specialise in board level repairs as it may be faulty GPU.
They have had a look at the display cable has sheered off, it's completely torn. They have also said there were two different replacement screens for the A1708 one which worked and one which didn't. Our supplier only offered one replacement screen option which is the one we fitted.
My question is has anyone heard of there being two different replacement screen options for the A1708 or experienced a display cable completely tearing and if so what was the cause?
Thank you in advance.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi
I haven’t heard of 2 replacement display types but I have heard of the display cables tearing because of a issue called flex gate
Flex gate is caused by the display cables bing too short which pulls them at bad angles causing them to tear over time
Apple did have replacement program but for this model it is no longer available
Hopefully this helps
Any questions please ask
Punteggio 2
2 Commenti:
Hi, Thank you so much for taking the time to reply. Our supplier hadn't heard of two display types either. We were aware of Flex gate as well but just wanted to check that there couldn't be other causes.
Thanks again :)
da
@infinitetechcon
Your most welcome
Let me know if there’s anything else I can help with:-)
da
Aggiungi la tua risposta
Athina England sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 16
Tutti i Tempi: 224
