Salta al contenuto principale
Lanciato il 21 settembre 2018. Modelli A2097, A2098. Disponibile come GSM o CDMA / eSIM o nanoSIM / 64, 256 o 512 GB /Argento, Oro o Grigio Siderale. (Si legge "iPhone 10 S").
398 Domande Visualizza tutte
Phone is frozen, and the restart does not work.
I can see the lock screen, but it doesn't react to touch. I have rebooted many times, it doesn't help. Please help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
Hi Ellen,
Unfortunately, there are quite a few reasons the touch screen isn't working.
It could be there's a hardware problem with the digitizer, which would mean replacing the screen, as the LCD and digitizer are fused together on your phone.
It could be a software problem as well. There are several things you can try, including an operating system update or a full restore. First thing to try, though, is a hard reset of the phone. Here's a guide to show you how (it's for an iPhone X, but is equally applicable to the XS).
How to Force Restart iPhone X - iFixit Repair Guide
Give that a try and let us know what happens.
Punteggio 1
I had something similar. The problem was in the accumulated moisture due to a sharp change in temperature. At least that's what the service told me
Punteggio 0
its still not responding to touch this could be a logic board issue if the iPhone x logic board even gets bent just a lil it can make all touch on the phone stop working
but this is the wrost that could happen so it's probably not this idk what else could be the problem
Punteggio 0
Aggiungi la tua risposta
Ellen Haljamets sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 45
