Salta al contenuto principale
Braun MGK3060 8-in-1 Face & Head Precision trimming kit
charging pins are corroded
the charging pins corroded, on both the device and the charging base are they replaceable?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@waltwlms they might be replaceable but are definitely not readily available. I would start by cleaning those with some distilled water/vinegar 50/50 mix and a couple of cotton swabs. Since those contacts are most likely nickel plated, the corrosion destroyed teh nickel plating. It is most certainly tedious since there is not a lot of room. Once the corrosion is removed, clean any residue with distilled water and cotton swab only. Apply a small amount of grease or some stuff that is called NO_OX_ID (not cheap and you would only need a very small amount so that could be overkill unless it is available to you) After that make sure that your charging base stay relatively dry.
Punteggio 0
Aggiungi la tua risposta
walt williams sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 264
