Mac super slow, a few pieces that are not attached inside found.
These three pieces are not attached and I was wondering if A: they’re the reason the Mac is nearly unusable as it has super high kernel task, and B: if it’s possible to reattach them
Update (08/15/2022)
Questa è una buona domanda?
4 Commenti
Caner - I've got some bad news ;-{ The IC pads appear to have the remnants of the logic board copper traces. So this will need someone with the skills to patch the lines.
The last time I saw this exact same issue someone had used to long a knife to lift the bottom cover off.
iFixit went to great pains to outline the steps and needed tools to lift the bottom cover off Sostituzione case inferiore MacBook Pro 13" Touch Bar 2017 as its very easy to damage the logic board.
da Dan
If U5860 is faulty or has been nudged I would expect the device to show your symptoms. They can be easily soldered back on. I would refer to the below answers as we don’t know what equipment or experience you have as Dan has mentioned you might need to run a trace or two if any of the pads have been damaged.
da Chris Stables
Caner Saka to rule anything else out, just post an image of YOUR board and let's see what this all looks like.
da oldturkey03
Looks like the outer solder pads are torn off but runnig a few traces should still keep it going for years :-) Do you solder or anybody around you have the right experience to do so? If not and depending on your location, you may need to send this out to get it fixed.
da oldturkey03
