Salta al contenuto principale
The Bose Wave Radio AWR1-1W, also known as the Bose Wave Radio I, was released in 1993. A countertop AM/FM radio system with a high performance stereo tuner and two independent alarms.
Bose Speaker noise sounds like Thunder
Intermittenly when I turn on my radio, the speaker noise sounds like Thunder. This does not happen all the time, and the only way to make it go away is to turn the radio off, and then turn it back on. Although, not even doing this will always work.
Any ideas of what this might be?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Hi
If the audio is distorted or could be a SOC on the main board but we should leave that as a last resort
I would open it up and check for any bulging or popped capacitors ,also if anything looks strange I would check it with a multi metre to check if there is a short of some sort
Also try reseating any connectors (possibly cleaning them with isopropyl alcohol as you go)just in case it’s a dodgy connection
And check if the issue persists
If the issue persists let me know and we can look into in further:-)
Hopefully this helps
Any questions please ask
Punteggio 0
Aggiungi la tua risposta
Coy Callender sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 21
Tutti i Tempi: 418
